Newbie here, has anyone seen this before on server 2008? [Error][Updated File] File Error="[com.ahsay.obc.core.bset.file.A] [BackupRequestTask.uploadFiles] Unexpected exception for caused by [java.io.IOException] The process cannot access the file because another process has locked a portion of the file.
Hi
Please check the VSS module hasn’t been removed from this account in your portal at https://portal.data-stor.net
If the VSS module is enabled, run this command from a command prompt (without the quotes) and check if any VSS writers have failed “vssadmn list writers”
Ahsay OBM 6 and 7
