BOBcloud provides the interface for you to backup to hundreds of 3rd party cloud and storage destinations worldwide without having to store your data with us.
Whenever you create a new backup account and backup set, you can select to backup to your own storage or 3rd party cloud and object storage.
If you want an easier solution, you can backup to our predefined destinations on Microsoft’s cloud [Azure] or Wasabi.
How to use BOBcloud’s Azure and Wasabi pre-defined destinations
Create your accounts on our portal as usual and open the BOBcloud software on your device.
- Add a new backup set
- Select the backup source
Our Azure destination might be pre-configured on your account. If so, it can be removed if you don’t want to store your backed-up data with us.
Remove the embedded BOBcloud destination by double-clicking on it.
Delete our destination (bottom left).
If you have any data on our destination, it will be deleted and purged immediately. We won’t be able to restore it.
- Add a new destination
Select the destination name BOBcloud on Wasabi (EU region) or any of the BOBcloud on Azure regions
