DO NOT COMPLETE THIS STAGE UNLESS SUPPORT HAVE REQUESTED IT
Migrating the backup software and backed-up data to v7
Stop all backups and restores and close down the backup software on your device.
Download the server or desktop v7 software from the B23 cluster at https://b23.data-stor.net/cbs/system/ShowDownload.do
If you have a rebrand, contact us first. -
Install the downloaded software over the top of your existing installation.
Open the software.
You will be prompted to enter the encryption password for each backup set.
Resubmit a backup. This time you will see the data is being migrated before backing up
- After the backups(s) have finished without displaying any errors, try some historical restores.
If the data restores correctly, the migration is complete.
Tags v6 move server, v7 migration
