How long does it take to restore a backup?
We have started using BobCloud backup for a period now and are satisfied with this software. Now we are about to move from testing to backup production data.
How long does it typically take to restore a backup? Anyone has experience restoring significant amounts of data, please share your experience with me.
Hi
The restore process depends on how much data you are restoring, the type of data it is, the speed of your internet connection and the speed of your system.
The restore times are comparable to the backup times, and you can check those from the logs.
