How long will my data take to update
How long will my data take to update?
430GB
Hi
The upload speed will depend on how fast your upload speed is and how much your data can be compressed.
The type of data will also be a consideration.
e.g. If you are backing up a million files, these will have a lot more overhead than backing up one large file twice the size. The overhead will comprise of handshaking, compression and encryption.
To obtain a rough estimate of how long the online backup will take, we recommend you use a local USB disk and a local backup.
This should complete relatively quickly and will confirm how much your source data can be compressed down to.
A basic calculation of your bandwidth and the size of the local backup will give you an estimate of how long the online backup will take.
Try our speed test tool here - http://uk-speedtest.bobcloud.net/
Ahsay OBM 6 and 7
