Is it possible to restore data from a web browser when on teh move?
Hi
Yes, this is possible via the respective customer’s page.
We recommend it is used to restore small amounts of data and the desktop software is used for larger restores.
The restore applet requires Java, so you might need to update the version of Java on your device before the applet will run correctly.
