MS SQL error on version 7 of Ahsay OBM ‘Skip backing up (Database does not exist)’
Issue
We can’t remove specific MS SQL databases from a backup set and have an error during each backup skip backing up (Database does not exist)
The AhsayOBM software doesn’t provide a way to remove specific MS SQL databases from a backup set.
The current fix is to remove the backed-up copy of the database from our service first.
- Open the BOBcloud (AhsayOBM) software on your device
 - Select Utilities
 - Select Delete Backup Data
 - Select the backup set
 - Select the destination
 - Select Choose from all files
 - Locate the database you want to remove
 - Click Delete
This action will delete the backed-up copy of the database.
When the backup next runs, it should complete without an error.
