View folder sizes
Hi, is it possible to view the size of a folder which has been backed up?
Hi
It isn’t possible to determine the size of a folder which has already backed up as part of a backup set.
To have this level of reporting, the folder in question would have to be within its own backup set on its own. You will then be able to view the size of the backup set.
Ahsay OBM 6 and 7
