Hey there, I’m a bit concerned about what will happen if my backup exceeds my storage limit. I have a lot of important files that I want to back up, but I’m not sure if I have enough space. What happens if I go over my limit? Will my backup fail? Or will it just stop backing up new files?
Hi
We don’t set quotas or sell storage by the GB \ TB. You can edit the quota from your portal if you have one set.
If you exceed the quota, the backup will fail to start. Running backups will continue past the quota as the quota is only checked as part of the backup pre-flight checks.
