I have just created a new backup account in our reseller portal and installed the client software on the server hosting the Hyper-V machines we want to backup. When I create the backup task the only destination I can select is local storage, no other locations are available in the drop-down list.
It’s been a while since I created a new account, but I don’t recall doing anything different when I last added a customer. Can you please advise if I’m missing something?
Thanks.
Hi
We’re not sure why this would happen if you are using a reseller account. It is possible this might happen if you create a trial within the desktop software because it won’t pick up your reseller environment. Some resellers have specific environments without cloud destinations.
If there is nothing obvious, please send an email to support@bobcloud.net with the backup account ID so we can check.
I’ve just checked our reseller portal and have now noticed that this account is shown as a trial. The customer has now asked us to pause implementation so we will be deleting this account anyway.
Thanks for your help
The customer now wants to proceed with so I have restarted the process.
I have added them as a customer via our Reseller portal and the account is still showing as a trial and I can’t see how to change this. Can you please advise where I am going wrong?
The customer name is
Could you please also provide the link and instructions for the Synology client?
Regards
Steve
Hi
The customer has been added with a slightly different name, so its trial has started with the new account.
The Synology installation tech doc can be viewed from the link below. Page 2 explains how to add the license. This must be done instead in the Reseller portal at https://portal.data-stor.net/
here - https://download.ahsay.com/support/document/v9/guide_obm_quickstart_syn_v9.pdf
The Synology module can be installed directly from the link below. I have also pasted the links corresponding to your SPK version on the NAS below.
If you require help with this, please get in touch with us directly on support@bobcloud.net
https://b22.data-stor.net/cbs/system/ShowDownload.do
Please copy and paste the following URL information into the “URL” text field during the installation
https://b22.data-stor.net:443?ownerid=0
